I was changing settings in my machine settings trying to get my limit switches working. I succeeded in getting the laser to stop working. I now have most everything working and moving in the right directions.
The only problem now is if I enable water protect in Vendor settings I get Water error work paused on the controller LCD screen. If I enable door protect in vendor settings I get Machine protected work paused on the LCD screen. I just checked and I had an older version of LightBurn running. I updated to 9,19 and I am still getting the errors.
Thanks,
Bruce
Sounds like you have a wiring problem, then. Since 2 sensors are having the same problem, you’ve probably lost something on the 24V rail, not the individual connections to the controller.
I am not even sure where to start to look for something like this. I kind of doubt it could be wiring the only thing I have done is change some limit enable switches in the machine settings.
Like I said everything worked prior to me changing some settings in the config, now I am having these issues.
Later tonight I will turn off the door protection and see what happens.
