Wonder if someone can help. I recently bought an expansion kit for my Atomstack bed and installed it. My bed is now 410 x 850, so I changed the Machine settings $131 to 850 as specified in the documentation of the expansion kit. I change the setting and save it and it saves. If I got out of Lightburn and then back in the $131 setting goes back to the old setting.
The inability to write permanent firmware changes is a known issue with a certain generation of Atomstacks. You’ll need to re-flash the firmware in order to write settings changes that persist through a restart. We’ve got a guide on that process here:
Don’t worry that it says it’s for the Sculpfun S9- Atomstacks fall squarely in the ‘or similar laser’ category.
