Machine setting not available in menu
Hello,
I can’t find in “Edit” the “Machine Settings”
I’d like to acces it to calibrate the axes.
If i’m not mistaken it should be right under “Device Settings”, “Paramètres du Périphérique”.
The values aren’t the same in lightburn than they are in real.
Thanks for the help.
Turn off Beginner mode = Mode débutant:
There are no machine settings for a galvo fiber… Your adjustments are only within the device settings.
