I’m losing connection. Machine settings go blank.
Only after I try to run a job. Screen displays job outside the work area. Do you want to proceed.
Also I have not yet been able to run my first job at all. Thanks for any help.
If it make a connection and then lose it, you may have a problem with the USB cable.
When I had an identical problem, I replaced the USB cable with another with a ferrite core and I didn’t have this problem again.
This happens when engraving/cutting and the dimensions of the project “may” be outside the work area.
Solutions:
In laser window select “Absolute Coords”
Check in “Device Settings” that the “Working Size” is not smaller than the project dimensions.
OMG. THANK YOU. It was the cord. I really appreciate the advice I was very close the giving up.
Thank you for the update.
Next time you know what you look for in the first place. But if are now using a ferrite core cable it shouldn’t happen again.
