After installing a new X-tool D1 pro 20W, the laser will only frame and return to home. The laser never fires. I discovered the machine settings selection, under edit has disappeared. The Settings and Device setting selections are still there. How do I get back the Machine settings ???. I was already using and X-tool extended laser on this computer and everything was working fine until I installed the second laser.
Installing a second laser would have no effect on the Lightburn windows. I just checked Beginner Mode and that would not do it. H O W E V E R, If you select Custom GCode, then it goes away because it is meaningless then. I just learned this myself.
Machine settings will come back in v1.7 for custom gcode devices
