Machines conected at same pc
it is possible with lightburn to work with two sculpfun S9 and S30 pro, simultaneously.
It’s possible from LightBurn.
Run LightBurn and connect to one of your engravers, set the profile in the laser Window to be correct for that laser.
Run LightBurn again… at the same time… It will let you!
Plug in the other laser as well and connect the same way.
You can make 2 different Lightburn icons on
your screen. One for each machine
Thanks for Thank you for your help.
