Id like to make a macro to turn the light/fan on and off. I have a Omtech 50w laser How do i find the information on this?
Because the Ruida controllers found on CO₂ lasers do not use G-Code, there is no way to send them commands apart from the binary blob defining the job.
So, unfortunately, the controller can’t do what you want.
Make sense. I appreciate you responding.
How did you configure the the ability to control the light/fan at all?
My ventilation is controlled by the status output. It becomes active anytime the machine is in run mode.
I wish i knew. Mine is the same way. If the machine is on they are on. I was thinking about putting a switch in somehow but havent figured it out yet. If i do find something ill let you know
I change my fan and, at the time, the aquarium pump that came with it to an Amazon ssr.
If you want to do this, sing out. It’s pretty simple.
