Since updating to the newer version I have lost the macros that I assigned.
Shouldn’t the macros transfer to the updated version (like the library does).
What folder location does lightbrun store the macros so i can hopefully restore these.
Yes, the macros should transfer like everything else. Did you create a new device, perhaps?
Everything is saved in one prefs file which you can find by going to File > Open prefs folder. Note that it is saved when LightBurn closes, so if you want to edit or modify the file, close LightBurn first.
