Made a RD file to help set scanning offset.
It is a file containing 20 squares that are engraved with a offset ranging from 0.05 to 1mm in 0.05 increments.
Just send this file to your Ruida controller and edit the speed you want and the power you need.
It wouldn’t be possible - you can’t save a DXF or SVG file with intervals attached, it would just be a bunch of squares. Time to download the trial and give it a go.
I need a little clarity on how to use this file. When I import the RD file and set it to fill, LightBurn has an issue because these are unconnected lines. How do I get LightBurn to run these as offset squares?
