Making a part into 2 pieces
I purchased a plan from Etsy and the base part exceeds my work space. How can I make this part into two separate pieces with finger joints? This will allow me to attach them together after the burn.
Here are two videos. The first shows you how to break apart a design into smaller parts as you’ve described. The second is an alternative approach to using the print and cut feature to burn larger pieces than your work space without splitting the design. It may or may not work in this case depending on the specifics of the design and your laser.
Cut puzzle using ‘Cut Shapes’ - YouTube
Cutting a single project larger your laser (pass-through version) - YouTube
