Making a tabbed box
making a tabbed box and tabs are loose. is it the kerf setting that you use to tighten it or something else?
thanks ron
Yes - If you adjust the kerf outward, it will move the laser out, away from the box itself, which makes the parts fit together tighter.
I recognize that this is not LB-specific… but with your interest in tabbed boxes, you might take a look at
boxes.py. And amazing array of parametric box generators that will allow you to easily generate SVG files that you can import into LB. Of particular interest, each generator includes a “burn” (kerf) parameter that allows adjustment of the “tightness” of fit… and a “burn test” generator that allows you to determine the burn value best for your laser and machine. No affiliation… just a happy discovery! :smiley:
LightBurn will do that too, and without the weird little curls on every inner corner:
