question which im trying to work out if its possible in LB
I am after making a template for using a router to cut a shape, so the size of my trim bit is 12.mm diameter which means that for an inside corner the min diamater i can cut is 12.7,mm.
So if i have a shape such as a number three then the point shown cannot be less than half the cutter diameter…is there a simple way to achieve this?
I will use some leftover wood and experiment with font sizes until I find a size that is neat and appropriate. Once you have found the size, you can scale text and numbers up to this minimum size.
