Is there an easy way to curve a rectangle? The only way I found is to create a rectangle, convert it to a path and then add smooth nodes to the middle. I’m willing to bet there’s a more simple way to do this. The process I use is tedious and often in accurate.
It also depends on what you want to end up with. Sections of two circles as the above, Could also be sections of a sine wave, depends on how you want it to look.
