Making DXF / SVG cut files from a JPG logo (red cut + blue engrave), looking for testers who import into LightBurn
Hello, I develop Nuvexel AI Pro, a Windows app that turns a logo picture into a DXF in millimetres: by default one red CUT layer (the object’s outline plus every through hole) and one blue ENGRAVE layer (the lines inside); with the option «Plate around the drawing» one cut goes around a plate and the whole logo is engraved (that is the file in the image). It can also write SVG.
If anyone is willing to try a file and tell me whether the layers, the scale and the closed shapes come in as expected, I would be grateful. The default is DXF R2000 (LWPOLYLINE); R12 is available for older software.
The image in this post is a real input and the real output of the same run. Video: https://www.youtube.com/watch?v=vYx_IV1irz4 · site: https://nuvexelai.com/ · contact: support@nuvexelai.com · 16-second Short: https://youtube.com/shorts/8vrB99y2Lao
upload the DXF here and add.txt to the extension
Thanks a lot for offering to look at it, Ralph! Here is the exact file from the image, unchanged, with .txt added so the forum accepts it. Please rename it back to .dxf.
What is inside, as written by the app:
  • DXF R2000 (AC1015), units millimetres ($INSUNITS = 4, $MEASUREMENT = 1)
  • Overall size 30.0 × 26.2 mm (exact extents 30.000 × 26.201 mm), origin at 0,0
  • Layer CUT (colour 1, red): 1 closed LWPOLYLINE around the plate, 110 vertices
  • Layer ENGRAVE (colour 5, blue): 36 closed LWPOLYLINEs for the logo, 697 vertices, all inside the cut outline
  • Only straight segments (no bulges, splines or blocks)
This is the “plate” variant: one cut goes around the badge and the whole logo is engraved. An R12 export of the same drawing is also possible if that suits LightBurn better.
I’d really appreciate hearing how it imports on your side: layers, scale, and whether the shapes come in closed and ready to fill or cut.
basecamp_logo_clean.dxf.txt (27.7 KB)
It has a lot of nodes(vertices), but everything is connected. Are your blue lines score or engrave(fill in LB)?
Thanks for checking it, Ralph, good to hear everything is connected!
The blue lines are meant as Fill (engrave). They are the closed outlines of the logo’s solid parts, so a Fill in LightBurn gives back the filled logo: the rings, the banner, the letters with their counters, the mountains and the star. The red line is the single cut around the plate.
About the nodes: curves are written as short straight segments at 0.02 mm tolerance, with no arcs or splines, so the file opens the same way in older CAD and R12 readers. That is why the circles carry most of the 807 vertices.
Here is a preview of the blue layer filled with the even-odd rule (rendered from the DXF itself):
Would fewer nodes help in your workflow? Thanks again for taking the time.
I personally don’t like a lot of nodes. Harder to edit. But, if it is a one off, it is probably OK. Personally, I would rebuild the cut lines, because it is a easy shape to create, but that is just me :slight_smile:
before smoothing
after smoothing
I have to say, this feels a lot like you’re using AI to write the messages you’re posting here.
We strongly discourage this - it’s overly verbose, always has the same “excited / friendly” tone, and just lacks character.
The giveaway for me is the part where it describes your picture to you, like you weren’t able to see that for yourself. (“the rings, the banner, the letters with their counters, the mountains…”)
Please, if you’re going to use our forum to advertise your vibe project, at least put on the effort to interact with us yourself, instead of through your agent.
I understand your indignation, I really do use an AI to write certain texts in English, because it is not my native language and I still try to write grammatically, because I do not understand the subtleties of the English language to understand such things, but the essence does not change, it is my personal one, but I communicate freely in Russian or Hebrew… that’s how things are, unfortunately. I’m new here and wasn’t aware that this was such a sensitive issue for you.
I came to this forum primarily to get support and opinions from professionals, since I am a solo developer and this is important to me in order to make my product better and more ideal in the future, especially for professionals like you.
In the next update, I will add more intensive curve smoothing to reduce the number of nodes,
or perhaps a slider in the program so you can adjust it to get the desired result.
I have been using Google Translate without negative feedback. You are using A.I. to write your material. Translation is just a benefit, not an excuse for using it.
I’m not offended that you use translation, but AI tends to add a lot of embellishment and tone. Direct translations from your own words are preferred.
We like stuff made by humans here. :slight_smile:
I understand, I will do my best.
