Making nodes visible
I am using Lightburn quite well to open and import files, convert them and create RD files but the very basic feature of making nodes visible escapes me! I can select all. Click on the edit nodes button. I can see the moving dashed line. Sometimes I can get nodes to show but I am not sure how! Please help!
make sure what your are selecting is not grouped together. Everything has to be ungrouped for the nodes to appear.
Brilliant! Thank you so much!
Shapes will also not show nodes if they are not paths. Basically, any shape that you created with the rectangle, ellipse, polygon, or text tools in LightBurn. To edit the nodes: select the shape, right click, chose “Convert to Path”.
You can tell if something is a group or not usually just by looking at it when selected:
https://lightburnsoftware.github.io/NewDocs/CreationTools.html#selection-tool
