Making sure that I have the right parameters to connect light burn to my snapmaker artisan
I am new to this software and I am getting conflicting information in making sure that I have it set up right and the everything that I am using is compatible.
My laser is a Snapmaker Artisan with a 40 watt laser. I can also use my 10 watt laser. As far as I know it uses G Code. The Light Burn software is a new purchase basic, therefore it should be the latest version.
I am trying to understand how to set up the Light Burn software with the Snapmaker Artisan. I am using a USB to a miniUSB cable to connect to my pc to my snapmaker. I have down loaded CH 341 SER to my laptop.
According to Snapmaker I should be getting as a machine profile " snapmaker-artisan-40w-v1.lbdev "
The software tittle at the top of the screen is “untitled> - Snapmaker -LightBurn 1.7.04”.
The device list shows “Snapmaker | GCode”
Find my device shows "GRBL-M3 (1.1e or) (10mm x 10mm)… (GCod… Serial/USB
??? Do I add this as a device?
Because I haven’t found the profile code listed by snapmaker I need to know if I am setting up the interface correctly.
The lbdev file should be on the USB stick or memory card provided with your machine by Snapmaker.
You have here the Snapmaker wiki with the .lbdev, after download just drag the file over your Lightburn window and it will be auto-imported:
https://wiki.snapmaker.com/en/general/manual/use_ray_with_lightburn_guide
