Pretty much the question, will you guys be implementing that option in the near future? I can’t seem to find anything similar in LB. I do small text marking on some lumpy parts with a crappy roller rotary and the split line option in EzCad is perfect for that.
Have you tried “Run whole shapes”? Is there a reason you need to manually specify the splits?
I did get it marking the way I needed, it just took some trial and error. I’ve tried checking the “Run whole shapes” option, but it still split some shapes and non hatched text. The mark by split line was just a much simpler and convenient tool for me to use.
What did you set as your Max Shape Size?
