HI
Newby , have followed steps for install and this appears
Have the cor file on provided usb and still get this error , help please
Unable to locate specified COR file: F:\jczEZCAD for ComMarker B4\200mm\jcz20.cor
You will have to manually load your COR file in Device Settings.
EZCad Config Summary:
Click Next if settings are correct.
Otherwise import another config or cancel.
- Laser Type: Fiber
- Fiber Source Type: IPG_YLP
- Field Size: 230 mm
- Field Angle: 0 °
- Enable PWM: Yes
- Min Freq: 20 kHz
- Max Freq: 200 kHz
- Enable Q-Pulse Width: No
- Open MO Delay: 8000 ms
- Correction File: Invalid COR file: F:\jczEZCAD for ComMarker B4\200mm\jcz20.cor
- Galvo 1 is X: No
