Hi All,
I have been searching for lase on during Traversal Moves problem on this form. But found nothing about marlin.
The laser stays on during Traversal Moves With in the same layer movement between different layers are fine.
. I have a basic laser, no PWM just on and off. Issue is not happening with various inscape plugins.
Also i saved the gcode to the SD card Rather then controlling with usb.
Which Device Profile do you have selected in LightBurn?
Did use Marlin. But reached out to tech support turns out light burn just doesn’t support on off lasers. Ordered El cheapo that has pwm control. Will have to give lightburn another try when it arrives. Thanks for responding
