Master Engraver (ME10)
I got this build and partially working and I have some questions on some things that are not working properly
  1. when I draw a 3 x 1 inches the representation on the laser output is like x10 and was wondering how do I make it 1:1
2 . End/stop (Homing switches do not work)
  1. On there software when I do the frame it fires the laser but Light burn does not
  2. It seems to move really fast including retracting to the next letter when I write " Hello World"( like it will write the “H” then zoom super fast speed to the “e” that it makes the whole machine shake
The ol’ cut-n-paste works fine also.
Get to the LB console and type $$ for a configuration list and post it here.
I believe you can go into Edit → Machine settings and read these out so you save and reload them. I know I can on my Ruida controller.
Did you go through the Lightburn grbl setup? Some of these variables need to be set properly.
Is it a mistake to think you know about the configuration information?
You can check the configuration for inches or mm.
$13=1 for inches or $13=0 for mm
You can change it on at the command widow by setting it to the required value
$13=1
it will write a 1 to it changing the machine to mm.
If you are working in mm, and the machine is ‘thinking’ in inches, when it is told to move 1 mm it will move 1 inch. That would really speed things up :slight_smile:
Configuration could be responsible for your home not working.
Has this machine ever worked properly?
I did the change $13= 1 and it did not make any difference and returned it to 0 again as you see in the picture
It almost look like my machine resolution(NEMA -17 spin) for travel( rotation) is not corresponding to when I tell it to travel an inch
You didn’t change it. It would have made a 25.4 X change.
maybe didn’t select write after he changed it :thinking:
Like I said I made the change from $13=1 and still did not fix my problem so I changed it back which does not reflect on the picture I posted
Just want to be clear, you changed it and ‘wrote’ it back to the controller. That should have made a major difference, so something kind of smells… :slight_smile:
$13=1 for inches or $13=0 for mm which are you operating in?
So I’m assuming you’re using inches and it’s set to 1. Still should have made a difference. :slight_smile:
