Matching screen work area with laser actual working field?
I have a NEJE Max4, and have been running it for a year+
I have ran into an issue I am not able to solve.
That prompted me to finish setting up my 2nd identical Neje Max4, and the issue is reoccurring on it also???
The field of work on my computer does NOT match the origin of my work on the laser field, and it is running out of field and away from the working field???
Im and experienced cnc operator/programer, and I have had my laser running successfully for a long time, but now have hit this problem and I can not move forward in production.
Any help / suggestions greatly appreciated?
Gabe
This can mean several things.
[1] Does the size of the Lightburn workspace not match the laser workarea?
[2] Does the location of the design not match where it burns/cuts on the laser workbed?
[3] Are you using Absolute Coords as your Start From position?
[4] Did you tell Lightburn where the Home switches are located?
Your controller type is likely GRBL. I am guessing that is what you selected when setting up the device type.
