When trying to do an engraving test after the x and y axis label and lettering are engraved, the laser the stepper motors send it as far as it can on the x and y axis (top right) when Trying to engrave the squares. it only does this on the engrave test, the cut test and everything else i have tried to engrave has worked fine. any ideas?
Can you check your preview to see if there is some mostly hidden shape (up in the top right) that may be causing this? If that does not solve the problem, can you post your project file and the support data (Help->Generate Support Data) so we could take a look?
