WND
(Amber Wilson)
August 5, 2023, 9:56pm
1
ok so we just got back from vacation. Turned everything on and lightburn needed an update. Updated it and ran a cut. All good. Updated mac and restarted. BOOM material library gone.
No big deal, reload it right? Library loads in with no settings… I’m not sure what else to try, but before I go running a bunch of test files and build a material library again I wanted to ask here.
jkwilborn
(Jack Wilborn)
August 5, 2023, 10:18pm
2
Don’t have a mac, Linux is what I run, but no operating system or patch is going to do this, at least it should not.
Can you find the file in order to open it?
I use this a lot and have never seen this…
WND
(Amber Wilson)
August 5, 2023, 10:40pm
3
Yeah I have the file in my documents. the file size is zero.
jkwilborn
(Jack Wilborn)
August 5, 2023, 10:47pm
4
If it’s empty I don’t know what to advise, but I doubt it’s a Lightburn issue as these are heavily used with many of the support people also on Macs…
I assume you have built this and saved it at some point… Doesn’t sound like you’d make a simple mistake like that…
I don’t know what to advise… I think @berainlb has a Mac… Maybe he can assist…
Good luck
WND
(Amber Wilson)
August 6, 2023, 12:05am
5
Now its not even letting me save the new library that I’m creating…
jkwilborn
(Jack Wilborn)
August 6, 2023, 12:31am
6
That sounds like a protection issue… where are you saving it?
WND
(Amber Wilson)
August 6, 2023, 12:35am
7
doesn’t even give me the option. I click save, it thinks, and then nothing happens.
jkwilborn
(Jack Wilborn)
August 6, 2023, 12:45am
8
Try save as … I suspect if you press save , it’s saving something…
If you know where it’s being saved, you could look… The save as option will tell you…
system
(system)
Closed
September 5, 2023, 12:46am
9
