Nobody specifically makes libraries for Atomstack, however, any comparable power library will work. So, I have libraries that I made into .clb files from several manufacturers from their white papers. The name of the library makes no difference, rather the power of the laser is what matters.
For example, the Ortur diode 20W (5W Optical output) will work with the Sculpfun 5W optical, and the Thunder 60W C02 will work with the OMTech 60W.
Keep in mind that library settings provided by manufacturers are suggested starting points and are not the end-all settings for particular materials. You still have to do your own testing with a raster or vector test grids on a sacrificial piece of material, and then adjust or add the cut settings in the clb file. What works on pine may not necessarily work on oak, and most manufacturers will only have a generic wood setting.
Libraries in a .clb format are freely available to download from the member’s only section of my Forum.
https://lahobbyguy.com/bb/
Rich
