Material Library for the Atomstack X30 PRO
Hello everyone. I need a ready-to-download Material Library for the Atomstack X30 PRO for LightBurn. I am a new user of the X30 Pro engraver, and I often have to repeat engraving multiple times despite previous material tests. Thank you in advance for your help. Best regards.
From the Atomstack website:
Parameter_Table_of_30W_Laser_Module_for_LightBurn_Software_2.pdf.txt (2.2 MB)
Remove .txt and add manually.
Thank you for the information. I have this table but I am looking for a ready file to import to LightBurn.
A material library will not help then. Lasering is about experience. You need to test, test, test. A material library that is created by someone else does not help at all. Those are settings that worked in a specific setup with the requirements of that user. General material settings don’t exist. Create your own library. If your material tests do not work out, you are doing something wrong, I think. Share a picture of your test and the result. Then we can help in doing it better.
Also, read here:
Material Library is specific to machine and material. Using one someone else created is not going to be very accurate. I agree with the above.
