Material Library gone?
Haven’t used my laser since the Holidays, went to open lightburn today and it froze the computer. Once I got the computer to restart and opened lightburn I needed to install my laser again the camera as well. I then noticed that my material library was empty. Where does it save the library? Can I retrieve my data?
First, you can try going to ‘File’ > ‘Load Prefs Backup’ and loading a preferences backup from before the crash. That should restore everything - your laser, camera, and material library.
If that doesn’t work, you can try searching your PC for a file with a ‘.clb’ extension. Then, load that file in the Material Library window.
Thank You the first option worked. Learned something new today Thanks again
