Material Library not loading right
I have just started working with lightburn but run into an issue with the material library.
I have lightburn on my main computer and a laptop hooked up to the xTool S1 in the garage. On my main computer i have setup a material library that i save on in a folder, which that folder i share with the laptop. When loading the material library on my latop the values of the material library change. For instance i have one that is set to 300mm and 90% power. When loading the library on my laptop it will change the values to 5.8mm and 90%.
I have also tried to just copy the library and put it on a USB drive and then copy it to the C-Drive on the laptop and then load it, but the same thing happens.
All the entries in the material library created using the option “Create new from layer”.
Any help would be appreciated to fix this.
Thanks,
Roger
…sounds like you have different units of measurement on your machines.
You are right. I had on on mm/sec and the other on mm/min.
It working right now.
Thank you Bernd.
Glad it was so easy, would you please mark the topic as solved? Others can then find a solution more quickly when they search for it.
