where can I find the material library in lightburn 0.9.16
Look under menubar “Window” for library:
It then may show up as a window or tab, depending on where you park it:
Make sure you have your interface set to advanced in preferences.
“Make sure you have your interface set to advanced in preferences.”
where can i find this???
Edit > Settings, and then at the top left is a switch for ‘Beginner mode’, though that shouldn’t affect whether you see the library or not.
It’s worth mentioning that the library is not filled in for you, unless you have a very specific machine (an Emblaser 2 by Darkly Labs). For that one machine, the manufacturer provides a library that is installed that works with their hardware. For anything else, the library is yours to fill in.
Thanks for all the info.
