What would cause my media library to not want to save? I can load a new one, but when I click save or save as, nothing happens.
Do you mean Material library? (just making sure I understand properly)
Save As should give you a pop-up for a new filename, and Save just saves over the old one. I assume youâve created one? When you say ânothing happensâ do you mean that you donât get the prompt for a filename with Save As? With Save, it just saves over the previous one.
Yes, the Material Library. I did notice that the save button does work, but clicking save as does not. I used to get the popup to save it, but now I donât.
The save function does work, but I canât get it to do the save as. Nothing happens when I click on it.
I am not able to reproduce using the latest beta running on a Mac. I select the âSave Asâ from the âMaterials Libraryâ window and am presented with a system-level dialog allowing file naming, directory navigation, and save functions. Are you saying you get no result at all when hitting the âSave Asâ button as I am showing in the gif below>
Correct. When I click âsave asâ, I do NOT get a pop up window to save it. It used to work.
What version number of LightBurn and what version/release number OS you are running?
Windows 10. V0.9.14
Noted, thank you. I must also ask if there is anything you can think of that might be unique with your setup as you are the first and only person reporting this behavior.
not that I can think. The only thing that changed since it last worked up was the latest update.
I do have LB setup on my MacBook pro too. I will see if that one works.
So it does work on my Mac. So there must be a security setting that got changed during a Windows update or something that is blocking it.
