Material Library wont unlink or unload
I moved some files in my harddrives and need to “delete” the org library file from lightburn as the link is no longer any good but it just says “failed to load” and when i click the unlink option nothing happens. the other libraries i have for my different lenses also wont unload even for the good links. is there an issue with the new updates? i cant remove any of my material libraries and now i cant even remove a dead one.
If your Lightburn version allows it try Export Bundle and export all.
After that do an Import Bundle and select only the ones you want.
that will let me export but I want to remove the material libraries so they don’t show
I figured it out, you cant remove a material library unless you load the device that the library is for so once I changed my device back to my old machine in the selection then it let me “delete”
