Ist das normal Ich will eine Furnierplate von 1,5mm schneiden ,doch ich muß 40mal eingeben um durchzukommen 3000und 100% ist eingestellt
Wie hoch oder tief muß der Laseropf sein um richtig zu schneiden
Is this normal? I want to cut a veneer plate of 1.5mm, but I have to enter 3000 40 times to get through and 100% is set
How high or deep does the laser head have to be to cut correctly?
this is the frame, tells little about the laser
From what i understand on Atomstack you can have the A5 with multiple laser head outputs.
IF is a 5W 4000mm/min 100% power is massivly fast
anything above >1000mm/min is engraving territory unless you havea a 20-40W laser head
Anything below 1000mm/min is cutting
For a 5W you would need to cut that to the 100s - 300mm/min area
I am not versed on AtomStack product stack (pun intended)
However is important to clarify always which power output your laser head has, regardless of the frame
