Material test and Ruida
Hello guys, I have an Omtech 50w Co2. I want to run the material test. My Ruida is set at 35% max power. when I open the material test dialogue, it shows by default 0 to 100% power. Is the 100% in Lightburn equal to 100% of 35% or will I blow my tube 3 times the suggested amp rating? Should I set my max on the material test at 35%É Thank yall
What do you mean or how/where did you set this value?
If your machine is setup properly, you cannot overdrive the tube, so to speak.
Enter the power you want, if it’s 35%, then enter that. The materials test doesn’t query any of the other layer settings.
You can save the current setup in the materials test, if you wish.
