I there a process to save the generated Material Test Card as a lightburn file.
My fiber lase is far enough away from my computer the frame function stops before I can set the material correctly under the Galvo head and position it for the test. Maybe I am just missing some step along the way
It’s not possible to save the generated test grid as a LightBurn file. However, in the next release of LightBurn, framing for the Material Test will be updated to frame the same way regular projects do for Galvo devices- ie, the red dot will frame continuously, rather than only briefly.
Thank You. That should help. Is the date for the new release be decided.
No release date yet, sorry.
