Material Test File problem
having trouble cutting through at 5mm/s and 10mm/s at all powers, not sure if someone could take a look and advise
Ruida RDC6442S-B, on a Red/Black 60 watt Chinese laser
as per test filematerial test pattern.lbrn (92.6 KB)
You are cutting at or below 10mm/sec, which is the default “start speed” in a Ruida controller. That speed means that it’s only using the Min Power setting, not the Max Power. This result is to be expected. If you’re cutting at or below that speed, set Min and Max power to the same value.
ok thank you
