I new to using lasers, but im a little confused.
Ive started with the material test generator ive put my rows in with my minimum and maximum speeds and power.
Ive had a look at the edit material setting and the edit text setting what do i need to set this to? and how does it affect the test?
Hi Joanna,
Clicking ‘Edit Material’ allows you to adjust any settings other than the two parameters you are testing with your grid. So if you are testing different combinations of speed and power, you could adjust the interval here, and that setting would be constant for all squares in the test grid. Since you’re a beginner, you probably do not need to adjust any additional settings here- speed and power are plenty to begin with.
Clicking ‘Edit Text’ allows you to adjust the settings of the text labels that will be burned next to your Material Test grid. These labels will show the parameters you are testing and the different values they are set at in each row/column.
