The Material test Grid is a great added feature, but all wordings and numbers are definitively burned much too high, going through on a 5 mm Plywood. I would suggest adding a possibility to reduce speed and/or power for the wordings & numbers, and maybe add the possibility to burn the material name on top as well.
Hi Phil,
You can adjust the settings for the words & numbers by clicking ‘Edit Text Settings’ in the Material Test Generator window.
You have to go into the color settings and set the text color parameters. I had the same problem.
I wish we were capable to pick what colors to use.
Thanks a lot to both of you guys, that helps.
