I think I have come across a bug when using the great Material Test function, I can’t save the Y and X Centre presets when I have reconfigured the Speed and Power parameters.
I can modify the other parameters such as min and max boundaries which save fine, but changing the Y and X centers does not save.
I am trying to change these to overlay a “Cut Out” file so that the Material Test results are cut out of the material in a handy square.
OR
Am I trying to do something that should be done easier another way, like modifying the Cut Out file to just work for the default and non savable settings, which I could use as a workaround.
Yes, it is a problem and a very annoying one too. I can’t understand why it saves all other entered parameters but omits to save only this one setting.
