Material test text in Galvo really small
The text in galvo material tests are really small compared to non-galvo. Is there a way to adjust?
Not currently, no. I would like to suggest you can add support to an existing request found here:
Update: In one of our internal channels, Oz offered:
I made it smaller because:
  1. people complained it took too long
  2. people complained it was wasting expensive material, and galvos can do tiny text, so why not?
I’ll have to double check that I’m correct, but I’m pretty sure the text scales based on the size of the swatches too. If you make 10mm swatches, the text should be larger. If you make 2mm swatches, the text doesn’t fit unless it’s smaller, so ask the user what his sample size is.
I just know when I do mine in Galvo the text is about an 1/8th the size of the numbers. Hard to read with old eyes. When using my diode the text is fine.
On the same axis? Top and bottom?
yes, on top and bottom
