Is there a way to edit the text in the material test program? I would like to use much less space for the text when testing very expensive materials.
Hello, Charles
Not sure there is any control to the text size on the legends, it would be nice though.
What I do is set the power to zero in the material test setting window, and just take a screenshot of the preview for notes.
A site like Lightburn PowerScale Generator - O2 Creative, or another like MGL pour Lightburn & LaserGrbl can be used to generate such material test.
With the advantage that you can edit them to fit your needs.
I have been putting my small sample on a piece of wood so that the test squares fit the material and the text burns the wood.
Thanks. I’ll check these out.
You can change the text settings as far as power etc separate from the grid if your only problem is burning
It seems that the v. 15, currently in public beta state, improves a bit this material test.
I haven’t checked yet if they allow to save such test as lbrn2 file, now.
