Material Test Tool
Hello. I wanted to try the material test tool in lightburn, but when starting, the laser just goes left until it is out of its range. And when i look on the preview, it is showing that the moving pattern is way outside the working range (both to the left and to the right).
Does any one have a suggestion about what is wrong / what to do, to fix this issue?
Thank you in advance.
Check your Text settings. They’re likely very fast or you have a high overscan set.
In the “Cuts/Layers” window, double-click the left mouse button for settings. Check and reduce the “overscanning” value.
Then go to the “previvew” window and check if the red lines have reduced.
I don’t think you need that much overscanning space.
Hey, that was exactly the problem. When i reduced the speed, the overscan also decreased. Obvious, thank you very much :slight_smile:
Yes, the overscan was way too long because of high speed for the text. When the speed was reduced, the overscan lenght also was reduced :slight_smile:
