I’m new to lightburn and I am trying to run a material test. When I go to set one up a material test and press preview its only showing the grid but not the speed and power intervals on the sides. How do I get this to show?
Welcome. Without seeing what your results are, I can suggest checking to ensure the ‘Enable Text’ switch, found at the lower-left of the Material Test Generator page, is turned On (green). That should produce the test with title text. ![]()
If I’ve missed this completely, share screenshots so we can “see” what you are experiencing, and we can go from there.
Then check the “edit text settings” window if the layer is enabled. Often this layer is disabled and therefore there is no output.
Yes, and apologies for not being clear. This option was added with the release of 1.6.00.
- New “Enable” switches for Text and Border options in the Material Test
LightBurn 1.6.00: User and Vendor Bundles, random orientation for Grid – LightBurn Software
For the 1.5.06 release, yes, As @misken suggests, check the settings for the text layer to ensure the ‘Output’ is enabled.
As a FYI, the OP is using 1.5.06. The switch for ‘Enable Text’ arrived with the release of 1.6.00. ![]()
