Hi, When I tell Lightburn that my material thickness is 3mm it will move to the job first then raise by 3mm. I have air assist with a pipe so would like it to raise to 3mm before moving. How do I acheave this?
Also when it returns to zero after a Job how do I get it to also go to the z height of zero (currently it is staying at the 3mm)
You can add a Z axis command in the GCode section of the Device Settings.
G1 Z3
Will move the head to 3mm above zero. Light burn will know it’s done it and not move it another 3mm once it has moved. You could take it higher and then Lightburn will move it back down to 3mm once in position.
Putting the command in as I suggested in the Start GCode section of Device settings will issue the command before Lightburn starts the burn. That will raise the head 3mm before any x or y movement.
If you want to return it to zero after the burn add commands to the End GCode section to reposition the head where you want
