Max -power atomstack x7 pro
Hello all,
I’m new here and have to ask something
How can you see if you use all watt power from the machine?
Power is hard to see but you can see measurements or results.
I’m looking for a visible light laser power meter but i haven’t found one in the 450nm range yet.
Most of the Infrared laser testers use a calorimeter type of tool to measure temperature change on a known material over time.
An oscilliscope could be used to measure or show that maximum power is being requested by the control board at the engraver. All that would mean is commanded power (the request) was confirmed.
There is so much variation from device to device and from material to material that test patterns are almost always the place to start.
