Max Power on machine vs power settings in Light Burn
Hi All. New guy here.
I am wondering how the max power on the machine settings combine with those power settings in LightBurn? To be specific. If I have the Max power on the machine set to say 60% and the power setting in a layer to 50%. Is this now 30% of the machines capability or does LightBurn override the machine settings and it is truly 50% of the machines capabilities?
Apologies if this has been asked before. Thank you!
¢hristopher £und
The pwm produced by my Ruida will map 30% power to a 30% pwm signal to the lps. Assuming no other limits at the time.
You can adjust the lps internal current control to limit your maximum current at 100% pwm. This will synchronize your percentage power value in Lightburn with percentage current through the tube.
On a Ruida, there are multiple places to put limits…
In the controller, you can limit the laser power, percentage wise to a maximum and minimum value. If your min/max in the controller is set to 30%/70%, then any value set in the layer < min will map to 30% and > 70% will be limited to 70%. Other values are not modified.
If the Ruida power values are set for a full range then power applied by min/max setting within the layer are scaled based on the start speed set within the controller. Works something like this…
Make sense?
