Measurement issues
Hi I have a problem, when insert a square 97mm X 97mm and try to burn it the laser functions fine but it burn burns 97mm on X axis and only about 10mm on Y axis, any suggestions please.Thanks Mark
You may want to review the section in LightBurn documentation that discusses machine settings and Axis Calibration.
Machine Settings - LightBurn Software Documentation
Ideally, you’d have the correct step/mm value in your GRBL configuration as per factory but you can use the axis calibration in LightBurn to attempt to manually tune it.
I did find this on Eleksmaker site. Not sure what model you have:
Hi Mate,
Thanks for the reply, I will have a look at this and let you know how I go.
Cheers
Hi
Got the measurements issues sorted, thanks for the help.
Mark
