Very new to this. Could not enough memory cause ports to disconnect or fail? Laser disconnects mid-burn. All port power management is turn off. Using Asus Vivobook 14, 8Gbs RAM, Windows 11
This runs on some very small systems, so I’d suggest you check the OS and make sure it’s not doing something for you, like turning your usb port off to save power.
It’s unlikely Lightburn, so I’d look at the OS or an environment variable for some other clue. By environment, other equipment starting, cables…
No, because a GRBL machine is just streaming the G-Code, character by character, at that point.
To an extremely good first approximation, random disconnects in the middle of a job happen due to communication failures on the USB connection. The usual solution involve getting a better quality USB cable to replace the junk shipped with the machine, plus verifying the cable isn’t getting wiggled / shaken by anything moving around during the job.
The usual advice is a cable with ferrite slugs on each end, although IMO the main advantage of the ferrite is to raise the price enough to pay for better QC on the cable wiring. However you get a better cable, it’s worthwhile. ![]()
Waiting for connection…
e[0;32mI (1334) serial: Line state changed! dtr:0, rst:0e[0m
ue:0.000000 spindle_pwm_max_value:1023.000000
Grbl 1.3a [‘$’ for help]
e[0;32mI (31724) serial: Line state changed! dtr:0, rst:0e[0m
e[0;32mI (32900) serial: Line state changed! dtr:0, rst:1e[0m
ok
ok
Homing
e[0;31mE (33375) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (33376) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (34026) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (34027) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (34028) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (34030) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
ok
Project loaded in 1 milliseconds
<Idle|MPos:3.000,3.000,0.000|FS:0,0|WCO:0.000,0.000,0.000>
ok
Starting stream
Stream completed in 0:00
Starting stream
Layer C02
Connection lost
Stream completed in 0:18
Port failed to open - already in use?
e[0;32mI (1295) serial: Line state changed! dtr:0, rst:0e[0m
e[0;32mI (1560) serial: Line state changed! dtr:0, rst:0e[0m
[VER:CV-30.V3.0.24.20221012]
e[0;32mI (2491) gpio: GPIO[13]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0 e[0m
e[0;31mE (2514) vfs_fat_sdmmc: sdmmc_card_init failed (0x107).e[0m
e[0;32mI (2515) gpio: GPIO[13]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0 e[0m
e[0;31mE (2516) sdmmcfs: Failed to initialize the card (ESP_ERR_TIMEOUT). Make sure SD card lines have pull-up resistors in place.e[0m
e[0;31mE (2518) sdmmcfs: TF mount failed
e[0m
e[0;32mI (2519) gpio: GPIO[15]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0 e[0m
e[0;32mI (2520) gpio: GPIO[2]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0 e[0m
e[0;32mI (2522) gpio: GPIO[14]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0 e[0m
[MSG:Axis count 2]
e[0;31mE (2631) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (2633) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (2634) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (2636) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
spindle_pwm_off_value:0.000000 spindle_pwm_min_value:0.000000 spindle_pwm_max_value:1023.000000
e[0;31mE (2639) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (2641) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (2642) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (2643) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;32mI (2858) serial: Line state changed! dtr:0, rst:1e[0m
ok
ok
ok
ok
ok
Homing
e[0;31mE (4190) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (4191) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (5834) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (5835) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (5836) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (5838) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
ok
e[0;31mE (12835) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (12836) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (12837) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (12839) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
ok
Starting stream
Starting stream
Layer C02
Connection lost
Stream completed in 0:08
e[0;32mI (1311) serial: Line state changed! dtr:0, rst:0e[0m
e[0;32mI (1546) serial: Line state changed! dtr:0, rst:0e[0m
e[0;31mE (2517) sdmmcfs: Failed to initialize the card (ESP_ERR_TIMEOUT). Make sure SD card lines have pull-up resistors in place.e[0m
e[0m
e[0;32mI (2521) gpio: GPIO[14]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0 e[0m
[MSG:Axis count 2]
e[0;31mE (2635) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;32mI (2846) serial: Line state changed! dtr:0, rst:1e[0m
ok
ok
ok
ok
ok
Homing
e[0;31mE (4162) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (4163) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (5521) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (5522) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (5524) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (5525) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
ok
Looks like typical USB communications failure, followed by the usual confusion caused by that failure.
Try reinstalling the firmware.
Jeff, have you checked your power management settings? We have a troubleshooting page on disabling the Windows feature that automatically turns off USB ports to save power.
I’ll update our troubleshooting page with directions for Windows 11, but in the meantime here are directions to turn off USB Selective Suspend in Windows 11.
What to thank everyone for their input. Found out it was something in the control module. Nice to see the support you get here when you have problems. Again, Thank you!!!
