Could this be an option for future versions?
As far as I can see/judge it shouldn’t conflict with each other, but will provide a welcome and important extra piece of information and possibly prevent some kerf settings that weren’t meant to be assigned to certain shapes.
S I X - S E V E N . . .
I look at both every time in the Cuts Editor window. I never know for sure what they are going to be.
I could see a future where perhaps you could set what options you want in the quick display yourself. Make a fider post?
I love this idea. As soon as @bernd.dk posts it, I will vote for it.
IMO, I think Interval and Kerf Offset are important enough to have both on the same menu
Thank you, it’s done.
One actually excludes the other, so I think the space can be more efficiently “reused” ![]()
(both functions/values can only be used on either Fill or Line)
Personally I think this would be the best option
The values at the top of that window are shared across all sub-layers, which would prevent you from being able to create thick text or other creative uses of Kerf.
Using multiple sub-layers, with different values for the kerf offset, allows you to create bold text, outlined, text, or other effects that are all compatible with Variable Text. Making Kerf a single value that was overlaid on top of interval would prevent that, as well as preventing the planned addition of Kerf to Fill layers.
