Menu Size for Right Side e.g. Font Symbols Cutting, Move, Library
The Current Slide Adjustments For Menu Tools and Font Size under “Settings” does not affect anything in the default (Right Side Menus) for Cut/Layers, Move, Library etc. My Dell PC Display Resolution is 3820 by 2400. All my other programs seem to adjust fine as does Lightburn in all the (Main Menu) areas after adjusting in settings. But the right area I mentioned above is un-effected and everything in these menus are way too tiny to be practical especially for us older guys above 60. is there anything i can do within the program to fix this and/or any fix coming that will correct this? Thank You in advance.
Hello there
Unfortunately, from my experience, this isn’t something that you can adjust. I believe the font setting you are referring to is the default font and size for when you use the text tool when designing.
I maybe wrong, but The only thing you can do here is adjust your text size setting in properties on the PC which will affect all on your PC.
Matt
