Thank you for the prompt reply. I hope that you can consider adding the functionality. Lightburn is a great product. I have three machines running of lightburn and it makes it much simpler to process jobs. The metal-non-metal machine operates perfectly from Lightburn only for lacking the mix cutting features.
I have attached the pics of the different setting required. Air assiat is handled directly from the controller.
If I can assist in anyway,please let me know.
Dear Alrich,
I am new to the mix cutter but using light burn on my RD6445 machine from Sri Lanka.
I want to cut 2mm GI sheet on my mix cutter with 400W CO2 tube.
Can you let me know the parameters to be used on mix cut settings.?
It is a great help. cmlaser@gmail.com.
