Qué tal? Me podrán ayudar? Tengo Sculpfun s30 pro. En Lightburn con los comandos mover, se mueve excelentemente. Pero a la hora de grabar o cortar dá pasos . En Laser gbrl corta y graba sin problemas y se mueve ok. Ya desinstale y reinstale, pero el problema persiste.
Are you saying that if you tell it to move 100mm with the arrow keys that is how far it moves? But if you make a 100mm square you get different results? Please post a picture of your results of the 100mm test square with actual dimensions achieved. Also, post a screenshot of your entire Lightburn screen(not a phone pic).
Gracias por Responder, si, la maquina se mueve correctamente desde la ventana “mover” y las distancias son correctas, el disparo laser funciona bien en esta ventana. CUando quiero ejecutar un corte la maquina dá saltos y no aparece la luz laser. LA potencia que estoy usando para corte es 80 y una velocidad de 400 por ejemplo y nada… ni siquiera lo graba. Antes no me sucedia. Incluso cambié la maquina por una nueva y me sucede lo mismo.
I do not see anything obvious in the settings you have shown. However, you have not shown all settings. Please go to the console window and type $$ then press enter key, copy and paste all output of that window here.
Your screenshot shows running at 1000 mm/min, you stated you were working at 400 mm/min. try slowing down to 100 mm/min and test again.
Envío lo que me arroja:
$0=10
$1=25
$2=0
$3=4
$4=0
$5=1
$6=0
$10=1
$11=0.010
$12=0.002
$13=0
$20=0
$21=1
$22=1
$23=7
$24=200.000
$25=3000.000
$26=250.000
$27=2.000
$30=1000.000
$31=0.000
$32=1
$100=80.000
$101=80.000
$102=250.000
$103=100.000
$104=100.000
$105=100.000
$110=6000.000
$111=6000.000
$112=1000.000
$113=1000.000
$114=1000.000
$115=1000.000
$120=1000.000
$121=1000.000
$122=1000.000
$123=200.000
$124=200.000
$125=200.000
$130=400.000
$131=410.000
$132=200.000
$133=300.000
$134=300.000
$135=300.000
ok
I do not see what I was expecting to find. Everything in your settings looks proper to me. I have no other idea at this time, sorry.
It seems you are using the extension kit, but you didn’t set the firmware parameters for it.
You are using absolute coordinates. If you do that, you need to home first. Otherwise, change to “current position” as starting position.
Show the console window, you will see some errors there, I guess.
Muchas gracias por el tiempo. Es muy extraño lo que sucede ya que en Lasergbrl se mueve sin dificultad, incluso realicé pruebas de corte y el laser funciona.
Si, he puesto el kit de extension. Pero incluso sin dicho kit tengo el mismo problema. Entiendo que no sería el área de trabajo lo que me está causando el inconveniente. La verdad estoy atónita, ya no sé qué más hacer. Gracias por el tiempo
Did you change to “current position” in LightBurn? Show all the screenshots as demanded here:
Les cuento que he resuelto el inconveniente. Desinstalé Lightburn, borré los registros e instalé una versión anterior.- Actualmente usaba la 1.7 (este procedimiento lo había realizado con la 1.7 varias veces) y ahora instalé la versión 1.3 y la Sculpfun s30 pro funciona perfectamente con esa versión.
He verificado los parámetros y son los mismo que tenía cargados en la 1.7 . La verdad, todo un misterio pero lo importante es que ahora funciona.
Muchas gracias por su tiempo e interés en mi inconveniente.
Saludos
